CBR 600 f3 "98" spluttering on wide open throttle
I need help.... i have a CBR600f 1998, The bike rides fine when bringing the throttle in slowly& will rev right through to the limit. But when i am doing around 30mph in 3rd & go to wide open throttle the engine splutters as if it is starved of fuel or air. This only happens on wide open throttle!
Any answers guys? |
Originally Posted by steevoz
(Post 838283)
Any answers guys? Also, when did it start happening and when did you change spark plugs last and cleaned the carbs... recent service history? |
Fuel pump working properly?
Thanks for your replies, It has always done this since i have had the bike. the last guy who had it was a bit of a numpty on it & came off twice..
Anyway, i have balanced the carbs & checked the jets for clogging. I have checked the resistance of the ht leads & coils, checked the CDI & voltage to the throttle position sensor. the guy who had it before me did say he had the problem too. |
hi just woundering if you have a slight missfire ,
my 1998 blade had this problem one min it was ok then it just wouldnt pull . i tried everything in the end pulled carbs off and found one of the ports used to balence the carbs had a slight air leak , replaced so they were sealed and havent had a problem since ( ecxept for the gear box) hope this helps. |
(Post 838283)
Any answers guys? |
you know, it sounds crazy... but did you let the bike warm up first?
i would check your main jets it sounds like ur sprayin to much fuel
