CBR 600 f3 "98" spluttering on wide open throttle
I need help.... i have a CBR600f 1998, The bike rides fine when bringing the throttle in slowly& will rev right through to the limit. But when i am doing around 30mph in 3rd & go to wide open throttle the engine splutters as if it is starved of fuel or air. This only happens on wide open throttle!
Any answers guys?
Any answers guys?
Any answers guys?
Any answers guys?
Also, when did it start happening and when did you change spark plugs last and cleaned the carbs... recent service history?
Thanks for your replies, It has always done this since i have had the bike. the last guy who had it was a bit of a numpty on it & came off twice..
Anyway, i have balanced the carbs & checked the jets for clogging. I have checked the resistance of the ht leads & coils, checked the CDI & voltage to the throttle position sensor.
the guy who had it before me did say he had the problem too.
hi just woundering if you have a slight missfire ,
my 1998 blade had this problem one min it was ok then it just wouldnt pull . i tried everything in the end pulled carbs off and found one of the ports used to balence the carbs had a slight air leak , replaced so they were sealed and havent had a problem since ( ecxept for the gear box) hope this helps.
Any answers guys?
Any answers guys?
KenG
CBR1000F For Sale / Found
08-09-2009 05:20 AM
