Carburator problems (floats and other stuff)
Isn't that just #27 on here? http://www.cyclepartswarehouse.com/f...1998&fveh=3047
yea, not the part. thats what the main jet screws onto...
i dont see what replacing those brass sleeves would do. 1.) its not a replaceable part, its pressed in, not ment to be removed. 2.) that sleeve is not a part that would suffer from wear and tear. what is the float valve? aluminum? save yourself from ruining you carbs and leave those brass sleeves in there. seek new float valves and float bowl gaskets. #'s 25 and 26 from the link...
happy that someone agrees with me, tho im not sure i understand what you mean by, floats leaking full inside the float?
like a hole or crack in a float? so they are filling and not rising? i think thats where your going at with it, just trying to make sure...
too late
heh, thats late, I already took those seat/sleeve out, they had some small filters inside and there was a lot of mug inside, Im looking for ones from another bike, all the floats seem to be ok, I already made a simulation with em and they float perfectly.
I hope I dont ruin my carbs , but I will keep you guys updated after I replace them. (could someone take a picture this seats to see the height?)
I will let you guys knwo what will happen after I replace them.
if you didnt fight to get them out, meaning causing damage or scratching/gouging/pitting the hell out of everything. you should be fine...hopefully. let us know how it works out....good or bad, lol
problem
Hi Guys, after synchronizing the carburetors and installing the new seats and nails, now the bike idles as a brand new bike, but .... there is a problem, it revs perfectly on neutral but when I put it on gear and try to ride it , after 3k rpms it begins backfiring, and it doesnt go above 6k/rpms.
Any clues ??
Any clues ??
