Carbs of a 96 f3 on a 98 f3?
Old Jun 2, 2023 | 02:50 AM
Timon's Avatar
Default Carbs of a 96 f3 on a 98 f3?
hi there!is it possible to put the carbs of a 96 f3 on a 98 f3? Would it drive just fine?
I think there is little difference in function and design I noticed that the model numbers of the parts are slightly different. I would also have to mount the boots of a cbr 600 96 on it.
96
97/98
Old Jun 14, 2023 | 03:15 PM
Cfoss's Avatar
Well, no one has answered you so I'll give my uninformed 2c.
The carbs themselves would probably work.
BUT
EFI is not typically just about fuel, but fuel and spark control. I don't know the EFI system, having not owned one, but the spark map would probably not work well without the sensors in place-typically an intake air temp sensor, throttle position sensor (the carbs hove one-not sure on compatability), map/maf sensor etc.
You will probably eliminate some or all of these with removal of the throttle bodies.
Then there is the fuel pump etc. (Possibly different pressure etc).
Are you missing parts, or would you just rather have carbs?
Chay
Old Jun 14, 2023 | 05:22 PM
rockpool's Avatar
The F3 doesn't have EFI - it's carburated.
Old Jun 14, 2023 | 05:44 PM
Cfoss's Avatar
Hmmm. Good point.
K nmind.
Might be different bores or jets. I would think it would work if you tuned it. There must be info on the changes somewhere.
C
Old Jun 14, 2023 | 08:07 PM
dannoxyz's Avatar
I suspect they should work fine. If needed, you may need to do some minor tuning.
Timon
May 24, 2023 01:57 PM
dyracuse
Apr 15, 2012 03:44 PM
dyracuse
F3 Wanted
Apr 4, 2012 07:43 PM
swanny338
Feb 7, 2008 03:17 AM
