Carb sync adapter piece?
Old Apr 15, 2012 | 03:27 PM
Hootie233's Avatar
Default Carb sync adapter piece?
Im about to sync my carbs because its idling rough and often stumbles and when trying to rev off idle. I am having trouble finding the adapter piece that needs to be used to hook up your line to the 1st cylinder.
I went to ace and homedepot/lowes and had no luck finding this m5 to 1/4" tube fitting. What does everyone else use? Is making my own the only way?
Old Apr 15, 2012 | 04:03 PM
MadHattr059's Avatar
They are about 3-4 bucks at the dealership. Sometimes it's worth it to just buy the darnthing.
Ern
Old Apr 15, 2012 | 04:05 PM
Hootie233's Avatar
Ern
3 to 4 bucks sounds more than worth it to me! Better than taking it somewhere to get the carbs done.
Old Apr 16, 2012 | 10:30 AM
marc0011's Avatar
I can't quite remember, but I think you need the 5mm adapter. Double check, but here is a link to the Motion Pro 5mm adapters.
Motion Pro - 5mm x P0.8mm Brass Carb Adapters (Set of 4)
Old Apr 16, 2012 | 01:39 PM
Hootie233's Avatar
yep its 5mm. I managed to find it on a parts site w/ a parts number but the local honda car dealers dont have the piece and the only motorcycle dealer is like 60 miles away. All the motorcycle shops are closed today so Ill try to go bum one tomorrow.
Here it is just for refrence #6 JOINT, BOOST
16214-MB0-000
Minnesota, Honda, Kawasaki, Suzuki, Yamaha, Ski Doo, Sea Doo, Can-am, KTM, Arctic Cat, Kymco, dealer, Brothers Motorsports
Old Aug 2, 2012 | 04:33 AM
SmokinCBRF2's Avatar
Registered Users
or you can pierce a 2mm drill through some hmm.. imbus screw as i did and attach a hose on the screw head... easy enough and you can spare your way for an adapter...
Tom Brosius
Oct 31, 2013 04:53 PM
vanalendur
Apr 30, 2013 04:26 AM
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
hss2010
Feb 19, 2012 01:30 PM
packdog
Apr 28, 2009 05:39 AM
