Can't figure out correct fuel mixture? Please help.
Info:
97 CBR F3
Denver (5k average riding elevation)
Yoshi slip-on
K&N filter
She couldn't get above 10k rpm under load no matter what I tried (in neutral she would just fine).
I put in larger mains (140 142 142 140) huge jump I know but the PO had them jetting 138 140 140 138 already and I felt she was running lean before I opened the carbs up. I threw in the larger mains just to see while I waited for the smaller ones, and she now can make it to redline but I have to hold WOT for a bit and she struggles to get there.
Throttle position has so discernable impact. I can crack it wide open and she'll climb just fine until 9k and start to sputter up to redline. Any ideas?
97 CBR F3
Yoshi slip-on
K&N filter
Info:
97 CBR F3
Yoshi slip-on
K&N filter
97 CBR F3
Yoshi slip-on
K&N filter
Thanks Cab, I just ordered some new mains and pilots. What is a DAI system? Dual air induction?
Also, if I were to bypass it, would I have to rejet? I also have the fuel pump bypassed, for what it's worth.
Info:
97 CBR F3
Yoshi slip-on
K&N filter
97 CBR F3
Yoshi slip-on
K&N filter
I know, I'm essentially wondering if there would be any downside to taking it off; if it cuts out a variable with no discernable loss then hell yeah I'll scrap it.
Didn't know you could, there's no clip notches on mine and I thought you could only shim it richer (washers) without moving a clip.
That's what I was confused about initially but I could have sworn it was running lean with how she was running and the fact I have an aftermarket filter and pipe (probably less of an impact on a/f ratio than I first thought). Unfortunately, for whatever reason I somehow didn't even notice the richened main jets the first two times I pulled the carbs so I ordered the bigger jets prematurely.
I'm going to order 130s, 132s, 135s, and probably 38 slow jets. Should I put anything else on that order before I place it? I'm sick of paying S&H for small mistakes. Thanks guys.
