Broke my thermo sending unit. :(
Old 06-10-2010, 04:25 PM
bammerman's Avatar
Default Broke my thermo sending unit. :(
Originally Posted by spicymeowmix
1) when you take the old one out, you have remove the air box.
2)then use a long socket extension to remove the old one after unhooking the sensor cable through the top between the carbs and frame (it will take some maneuvering, be patient)
3)when putting the new one in, do not, do not, not not not overtighten it, and ill tell you why most of us did... after its finger tight and a quarter turn more like it should be, there are still plenty of threads left (looks like it needs to be screwed in more) and it doesn't sit flush because of it. looks like it should be tighter because it doesn't sit as far in as the last one... so just a heads up.
I didn't even get to step 3 before my original one seized. Now I have no clue how to do get out. I am thinking of an extract bolt but not sure what size I will need, how to get it down into that small area, and how it will work with brass. Anyone else have this issue and what did you do to fix it?
Old 06-10-2010, 05:05 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
honda can take it out.
Old 06-10-2010, 05:08 PM
bammerman's Avatar
I like your PM solution of leaving it alone better.
Old 06-10-2010, 08:10 PM
buy another sensor, cut the rad hose, and make an inline screw in between them, clamp it down and you are good to go
Old 06-10-2010, 08:19 PM
orangef3's Avatar
when mine broke i drilled it out with an angled drill and if i recall correctly a 3/8 bit...retapped hole and screwed the new one in...works like a charm
Old 06-13-2010, 04:57 PM
bammerman's Avatar
F*** my buddy said he could get it out and cracked the metal around it. Now what?
Anyone know how I can remove my engine I can't find the manual. Maybe I can tig it back together. I tld him we should just leave it like spicey said, but he is a mechanic and said he got this. So what to do? Buy a head, weld - drill and tap, or just JBweld it?
Will an F2 head fit on a F3? I found one for a descent price.
Old 06-13-2010, 04:59 PM
bammerman's Avatar
Found a new head with shipping for 185. descent price? Doesn't come with the cam or lifters
Old 06-14-2010, 12:48 PM
bammerman's Avatar
I guess my friend (pro-welder) says he is going to try to weld it back together then drill and tap the hole after. Just have to remove the engine (what fun) but at least I can paint the frame black instead of the silver stock color. Do not think that will go well with a camo paint scheme as compared to a flat black. Figure I will buy a head just in case though. never know
Old 06-14-2010, 04:33 PM
make sure you use high quality paint.
im glad things are moving along for you.
personally i wouldnt worry about your temp sensor... just fab one up later
Old 06-14-2010, 05:10 PM
bammerman's Avatar
well it is leaking anti-freeze now so I will have to patch weld the tiny crack and then tap and drill the hole for the new sensor. Wish my buddy wasn't so damn ambitious and left it alone like you said.
Quick Reply: Broke my thermo sending unit. :(
