bought another CBR this one non running anyone want to help?
#21
Sync'ing the carbs is something that has to be done while the bike is running and warmed up, and after a complete tear-down and cleaning, it's a must. So factor that into the cost as well.
It's ridiculous what shops want for cleaning carbs. I did it for a few neighbors for $15 because I was bored on a Saturday! By all means, if you think you're going to break something, take it to a shop. But just remember about the sync, and that there isn't a guarantee (I've had to fix shops' mistakes for friends before).
As far as ultrasonic - post some pictures with the bowls off and lets see!
#22
#23
#24
If fuel really gums that up (at the elbow, closest to us in the picture), you can't really blow that out or get physical (like copper wire) with it. And since it's plastic, you can't really soak it in an abrasive cleaner like you can with the jets, hence ultrasonic cleaners.
I don't really understand why they use a vacuum assist to get fuel into the carbs like that (and why you'd need it on a Kat 750 engine???) - but none the less, we don't have an assembly like that, so unless there was some venturi or something that he didn't think he could physically clean, we don't need ultrasonic cleaners (which are just repurposed jewelry cleaners, btw).
#25
I purchased a small 2 quart Ultrasonic Cleaner from Harbor Freight. It's nice to have and use because it does a really nice job on those small tiny holes that are easily clogged like the 2 you see in the photo below. You're not going to be able to poke a wire inside there to clean them out. I think $100 is crazy money to charge to do that extra step though.
Those two little holes at the base of the brass butterfly are easily clogged.
#26
#27
#29
#30
When you put the carburetors back on the bike, naturally the bowls will be empty of fuel. That means that it can take a bit for the fuel pump (which doesn't prime like a fuel injected bike) to fill them with fuel.
To help in that situation, you can temporarily bypass the Fuel Cut-Off relay (located on right side of bike next to the R/R) by disconnecting the relay, and jumping across the Black and Black/Blue wires. This will cause the fuel pump to run as soon as you turn on the ignition key. In 10 or 15 seconds the bowls should be full and you should be able to start the bike with the choke on pretty easily.
Good luck and let us know how it goes.
