Bogging down
Old Jun 22, 2006 | 11:50 AM
speedfreak chick's Avatar
Default Bogging down
Ok, so the past couple days I've noticed that my bike is getting picky when the temp gets hot. It runs fine when it first starts up, but when I get it warmed up and go to take off, say from a light or in traffic, it bogs way down, and if I give it full throttle it continues to bog down and then TAKES OFF. If I keep the RPM's up higher than 4 or 5k, it's ok, but if I let it idle at the light, it bogs when it's time to go. The fan is kicking on, I can hear it, so I know it's not a simple overheating issue.
So far we've checked the coolant to make sure it had some in it. I thought maybe I had gotten a bad tank of gas, so I ran some stuff that was referred to me called "Sea Foam" which is a carb/fuel cleaner. It was actually much better for a while, but as soon as I put more gas in it, it went to **** again.
I don't know if my carbs have been jetted before I picked up the bike, because I don't have the history for it. I know I haven't done it. And I recently replaced the flywheel inside the stator, and gave the battery a fresh charge. I also did a chain adjustment, and bumped the idle up just a touch. It was idling before at a really low RPM, and I bumped it up to 1K.
Everything ran ok all through bike week, and the day after bike week this began to occur. The temp when it started was roughly 96-100* outside, but the day after it was roughly 80 - 85* outside. The temp when I've noticed this going on is roughly half way to 3/4 way on the gauge.
Any ideas? I don't want to randomly rip the bike apart, so if anyone's gone through this before, I'd LOVE the advice!!!
Thanks guys!
Old Jun 28, 2006 | 01:51 AM
mattleo's Avatar
Default RE: Bogging down
this happend to me i actually had 2 fouled plugs... and the bike was runnig on 1 or 2 cylinders and then the other 2 kick in and the bike rides normal. change ur plugs thats the problem hands down
Old Jun 28, 2006 | 08:53 AM
sun of a.....that's the worst project on that bike. :sigh: Ok, thanks for helping me determine the issue. I appreciate it!
Ickis
Jun 28, 2012 10:10 AM
hooberjabber
May 6, 2012 11:08 PM
Slavo04
Jul 17, 2009 01:10 PM
2bikes
May 11, 2008 01:19 PM
Ski
Jul 20, 2007 06:43 PM
