bike wont start
bike wont start
ok so heres the problem i jst bought a 95 cbr600f3 for $400 when u turn on the ignition the lights all come on put the kickstand up the orange light shuts off i hold in the clutch and push the start button and nothing happens the headlight dims it doesnt click at all i checked if it was on run or stop its on run. battery is good i checked that when i jump the selenoid it turns over but wont start if its getting fuel and spark what can be the problem i bought a new selenoid when i plug it in the fuse pops but with the old one in the fuse doesnt pop my biggest concern is jst getting it to turn over with the push start button and then i will go from there and what wires do i have to connect together to bypass the kickstand safety thanks
RE: bike wont start
I had the same problem... Pull one of the spark plugs wiresand check for spark.
I had to bypassed the clutch switch with a jumper wire, and grounded tha neutral indicator switch to get mine to fire up. Also check all the connectors behind the gauges, one of mine was not fully seated.
