Bike wont start
Old May 25, 2011 | 04:22 PM
joefrai5er's Avatar
Default Bike wont start
Ok well i just purchased a CBR f3 1996. I have had it for about 3 weeks.
THE PROBLEM
The battery that came with the bike was pretty low, so i got it charged. The bike was riding fine until 2 days ago. The lights would come on but the bike would not start. So i figured it was the battery. I attempted to jump the bike but in the process of doing so the cables started to spark. As soon as i put the cables onto the good battery to jump my bike, the bikes power completely cut off, ie no lights, no dash lights, and definitly no start. I again figured the battery was completely dead so today i bought a brand new one, i put it in and now the bike's dash nor lights will turn on, and a start is out of the question. I thought it was a fuse so i checked them all and they were all good. Any idea of what the problem could be?
Old May 25, 2011 | 04:44 PM
Kuroshio's Avatar
Moved to F3 section
Old May 25, 2011 | 07:36 PM
You've most likely blown the 30A fuse. It's by the battery mounted onto the Starter Relay. Taking the tank off makes it easier to get to.
Old May 25, 2011 | 07:56 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
did you jump the bike with a car?
was the car running?
Old Aug 23, 2011 | 08:31 PM
Seventy4blazer's Avatar
how many other hidden fuses are there on a F3?
Old Aug 23, 2011 | 10:21 PM
CW2_Talley's Avatar
kinda dumb question did u put the cables on right. sparks when u put them on?
Old Aug 26, 2011 | 09:33 AM
mcrwt644's Avatar
it sounds like you blew the main fuse...see post above...there are additional fuses under a panel secured by one phillips screw on the right side of the upper fairing next to the guages.
If you jumped it with the car running, you very well have cooked something. NEVER do that. A car that is turned off is fine, not running.
Also, if you reversed polarity on the cables? you would've fried the main fuse...aka, put positive cable on negative and vice versa...got to be careful
willie72
Oct 26, 2022 04:53 PM
aperez18
Feb 19, 2014 11:13 PM
CBRbanas
Mar 3, 2012 11:52 PM
tagger609
Jun 27, 2008 02:09 PM
demonchild
Jan 31, 2008 01:42 AM
