bike sounds like a diesel!!!!
Its sounds like valves or lifters I dont know.
Its really random it wont do it at all on cold starts sometimes then others it will and same when the engine is hot
I checked the oil and its good I tried different gas and nothing.
The only consistent thing is that it does it only below 4-5k RPM, above that the sound goes away and gets dramatically quieter.
The bike runs really strong too
HELP!
HELP!
Sounds like the Cam Chain Tensioner (CCT). Do a search on here and you should find a ton of topics on it. Itisaround $50 to replace it yourself if I recall correctly. Very simple to change out (2 bolts).
oooooh interesting,you could be right
the only thing is that if I had to pin point the sound I would say its coming from the top of the motor
not the lower left where the CCT is, right?
There's no sure-fire way to KNOW it's the CCT, but the symptoms you describe let me know it's about 99.9 % chance it is. The valvetrain on these engines are pretty much bulletproof, so I highly doubt it's that. A rattling sound like marbles in your top end in the RPM range you describe point to the CCT. It's a known weak point on a LOT of Honda inline 4 engines. (F1-F4i).
Plus, if you've got over 10-15K miles on your engine, it's just a matter of time before it will start rattling anyway. Just go ahead and order the new one. You will need item #5 (the "lifter assembly", or CCT) and item #1 (new gasket). Also, be sure to order the updated CCT (the part number ending in MAL-305). Ronayers has always had good prices on OEM parts: http://fiche.ronayers.com/Index.cfm/...N_-_F3_-_95-96
Let us know how it goes.
-Eric
-Eric
My bike has the same noise just not as loud as you say yours is. It has about 32,000 miles on it and looks like it has a new top end. Where can i find a manual tensioner for it and which one is better?
my local dealer actually had the oem cct in stock! they want $75 for the gasket and cct
i think im just going to order the ape cct offebay
how does the oem cct install? it has to be harder than just two 10 mm bolts
