bar ends from ebay don't work!
I got these off ebay and the throttle side bar end won't work!
http://cgi.ebay.com/ebaymotors/POLIS...mZ280162684326
if i install it with the rubber on there it expands and won't let the grip twist, if i install it without it threads in to to the bar end too far and won't let it twist smoothly... wtf. i thought someone on here said they had used these and the seller says they work on F3's as well.
[align=left]hey ptownsi, i bought the same exact ones and had the same problem. on the throttle side, the ends are made to thead in a certain way because what plafulgod is saying. I cut a washer in half and put it in there and then spaced it with a rubber bushing i tightend ddown against it. there is not a noticable gap and the throttle does not stick. look in the the right side of the bar and you will prlly see what im talking about. good luck!
[/align][align=left] [/align]
