Anyone have an extra radiator thermo switch laying around???
Old Jun 22, 2009 | 10:41 AM
A4wheelin's Avatar
Default Anyone have an extra radiator thermo switch laying around???
Mine has failed so the fan doesn't turn on at all. If I disconnect the wire going to the switch and ground it out the fan turns right on. So I need a new switch. I'm too poor to get a new one for $48 so I was hoping someone here maybe had one laying around. Thanks!!!
Old Jun 23, 2009 | 03:53 PM
dementedf3's Avatar
just ground the wire out to run all the time. better than not running.
Old Jun 23, 2009 | 04:21 PM
ty1854's Avatar
Wire it on a toggle switch until you can get a new thermo switch for it. Also check Ebay you might be able to find one on the cheap there.
Old Jun 23, 2009 | 08:07 PM
A4wheelin's Avatar
I think I'm going to do this. I'm not good with wiring stuff so I'm not going to do the toggle switch.
Old Sep 20, 2010 | 12:12 PM
manny38's Avatar
Try Bernies motorcycles on 01420561569(00441420561569) or 07772457294 (00447772457294). He sells good working second hand parts. Have been buying from him for years and never had a problem.Tell him that Manny from Gatwick refered you....hope it helsps
Old Sep 20, 2010 | 03:22 PM
mikeyfish's Avatar
wiring the fan to run all the time is better than not at all but its not really good for the engine either. An engine is supposed to reach a certain temperature to run correctly and efficiently so you need to get that fixed whenever you can. it will work as a temporary solution but dont go too long like that,
Mike
Rabid
Oct 19, 2010 02:10 PM
manny38
Sep 14, 2010 02:16 PM
extreamtacoma
Jul 29, 2010 08:56 PM
alejandrof2
Jun 6, 2008 09:08 PM
SHugo
Apr 6, 2008 10:38 PM
