Also, where do I add the oil????!
Old 04-10-2006, 06:41 PM
SEAN_VANCE's Avatar
Default Also, where do I add the oil????!
Also I have a 97 CBR...where do I add oil? DO I have to take off fairing? OR do I add through same hole of dipstick?
Yeah I know I need to buy a manual!
Old 04-10-2006, 10:53 PM
Default RE: Also, where do I add the oil????!
Add it through the dipstick hole.
Old 04-11-2006, 05:37 PM
sounds like ur first bike
Old 04-11-2006, 11:20 PM
rafo!'s Avatar
lol.no offense...............
Old 04-12-2006, 12:22 AM
If you're asking where to add the oil you should be bringing your bike to someone to have it worked on. Don't hurt yourself.
Old 04-12-2006, 12:57 AM
Do you have a owner's manual? It would help out a ton.
Old 04-13-2006, 06:37 PM
SEAN_VANCE's Avatar
Well yeah first bike, so Im clue less! No offense taken....Im a proud newbie and i ride like a 10 year old (for now)
I know Im going to drop it too and its a shame cos it has a fresh paint job! lol
But Im trying hard to be conservative for now, so I learn slowly...
anyways, yes I need a manual....so is the final veredict to add trhough dip hole or what?
Old 04-13-2006, 07:14 PM
denhou1974's Avatar
Hey Sean, it's a valid question for a new rider. Just add through the dipstick hole. Make sure that the o-ring from the dipstick doesn't fall down into the hole (guess how I know about this). Also, I'd suggest using a new washer (aluminum) on the oil pan drain bolt and a torque wrench set to the correct torque value. It's easy to overtighten the drain bolt and crack the oil pan (guess how I know about this) - actually, the previous owner did this one but I had to fix it. It's possible to change the oil without removing any fairings.
Old 04-13-2006, 08:50 PM
SEAN_VANCE's Avatar
Thanks for the tips!
Old 04-13-2006, 11:11 PM
Change the oil without removing any fairings yes. Change the oil filter though??? How did you manage that one??
