98 F3 fork adjust? Brake's to the left?
EDIT:98 F3 Triple Tree "Swivel peg" Loose?
Ok so, I got in a wreck and a lady bent my front forks. Got a used replacement set along with the triple tree. It feels very loose when taking corners and feels really soft up front. Idk what the shocks are set at as far as soft/hard goes or what spring it has but my old forks had a 1k spring. Is that the big difference I'm feeling?
Also now when I front brake it veers to the right...could that be that the shocks aren't set equally? Or something withmy brakes?
^^SOLVED^^
vv NEW PROBLEM vv
So now i'm noticing that right at the upper berings in the Top Triple Tree is wiggleing when under heavy braking and over bumpy roads...could this be the cause of the wreck? cause i dont see how that would b normal...
^^SOLVED^^
vv NEW PROBLEM vv
Well I just put them on the bike. And do plan to rebuild them and replace the spring in them cause I had a 1k spring in my old forks.
BUT....
1) found out I didn't check tire pressure and it was REALLY low causing the wable.
2) I have a new problem that when going over bumps and hard braking the swivel point for the Handel bars going from lower to top triple tree's is slightly moving forward and the back. I'm talking like milimeaters but it's still movement. Could I have bent that pin in my wreck? Or is a is Little play normal?
BUT....
No, play in the head bearings is not right. Probably why it's pulling to the side under braking.
Did you put new bearings in with the new bridges? Is it possible the front end hit elongated the headstock where the race sits?
Lifting it from under the stem should be OK. I wouldn't have it sitting on the wheel or be lifting on the bottom of the forks though.
yes. with the front end off... tighten the lower bridge nut to an initial torque of 18ft lbs. fully rotate the lower bridge from left to right at least 5 times. then re-torque to 22 ft lbs. Then install a new lock washer and tighten lock nut finger tight to align grooves. put on the top bridge and temp install the forks.. tighten top bridge to 76 ft lbs...
Smokinjeff
I did not replace the bearings or anything. I hadn't taken the forks off before and the forks were not sliding out properly so we removed just the stem bolt to remove the top triple brace and that allowed enough play for the forks I guess cause they slid right out after that. It is possible that happened cause I was struck from the front head on and F'd my forks pretty bad. I wish I could tell if it was from me removing the nut and it not being re-tightened properly or if it needs bearings. (most likely need bearings)
Will.bass
Since I only removed the stem nut so I need to replace the lock washer at all? Or only if that is removed?
Will.bass
Smokinjeff
Will.bass
Will.bass
why guess when bearings are cheap you only have to go a couple of steps further to replace them. id go ahead and do it, besides, the stem bearings that came in these f3's are obsolete now, you would be improving your front end by replacing them with current bearings.. (taper cone vs. the crappy ones)
Link for the ones i used
and this is what my old bearing races looked like..
