97 f3 starting prob
Old Mar 20, 2011 | 10:05 PM
Monster F3's Avatar
Default 97 f3 starting prob
So my bike ran just fine this fall. Had to have float bowl gaskets replaced do to leaking fuel. Anyway was nice out and tried starting it yesterday and it floods out in a matter of a couple turnovers and starts backfiring. Pulled plugs and turned it over to dry it out and cleaned plugs. New plugs last year. It will attempt to run if u keep starter engaged now but still wanting to back fire. Only thing I can think of is something is screwed up from when they put carb back together. Any ideas. Needle and seats?
Old Mar 20, 2011 | 10:13 PM
Stebdawgsf3's Avatar
Default stuck floats?
it could be a stuck float or valve if you used too much adhesive to put the float bowl gaskets on. then the gas would feed in through the main circuit. i would def check the carbs again. it wouldnt hurt to check the choke plungers to see if they are stuck..... thats where i would start.
Old Mar 20, 2011 | 11:42 PM
Cinderfella's Avatar
Check the float valves. They're really the only things that would make your carbs flood.
brads94f2
F2 Tech
May 2, 2013 11:49 PM
89cane
Mar 5, 2009 10:17 PM
Mr.B.S.
Apr 29, 2008 05:44 PM
tdiv135
Mar 25, 2008 04:24 AM
OCTOPUS
Jun 24, 2007 02:48 PM
