97 f3 need help!!!
Old 02-12-2012 | 04:10 PM
Haulin''s Avatar
Default 97 f3 need help!!!
my 97 f3 was running fine until i let the battery die, when i charged the batt. the lights will come on but when hitting the ignition all lights dim, will not crank or turn over, ive tried to bump start but no luck, any advise will help.
Old 02-12-2012 | 04:53 PM
MadHattr059's Avatar
Check under the tank, just forward and to the left of the battery box. You should
see a red connector. That's your starter relay. Saddled to the side of that, under
the connector is a 30amp fuse. That's your main. Check it and see if it blew.
You'll have to pull the side-covers>seat>tank to get to it easily. Don't forget to
switch the petcock to off, before you pull the fuel-line.
Hope this helps, Ern
Old 02-12-2012 | 06:09 PM
Haulin''s Avatar
i just took the tank and took a look the fuse was not blown but i swapped the fuse, and some other fuses, but the bike still does the same thing and refuses to start????
Old 02-12-2012 | 06:31 PM
Bladez89's Avatar
Could it possibly be the alternator is faulty?
Old 02-12-2012 | 06:47 PM
Is the battery good? Try charging it to full, again. Put a dc meter on the battery terminals
directly. It should show about 12.9 volts. Turn the key on while watching
the meter, it should, over about 20-30 secs, slowly drop to about 11.4 volts. If it
doesn't have 12.5+ volts with the bike off and/or goes below 11.4 volts with the
ignition on (with headlights), then pull the battery and have it tested.
If it's bad, that's your problem. If not, let me know and we'll go from there.
Ern
Ern
Old 02-12-2012 | 06:55 PM
Haulin''s Avatar
will try that, thanks
Old 02-12-2012 | 08:10 PM
Haulin''s Avatar
batt. is fully charged, still no luck it will not roll start,
Old 02-12-2012 | 08:28 PM
jveach's Avatar
When you push start it, does the motor turn over or tire slide?
Old 02-12-2012 | 08:30 PM
sjona2011's Avatar
+1 for what mad said
If the battery is in fact bad then go ahead and hook a charger up to it and see if it will turn over
If it doesn't then its not only the battery
Old 02-12-2012 | 09:03 PM
Haulin''s Avatar
the motor will turn over when being pushed so its not locked up, i have had a battery charger hooked to it, says its full charge
