97 600 cbr f3 help!!!
![Unhappy](https://cbrforum.com/forum/images/icons/icon9.gif)
So i just picked up a f3 for a pretty cheap price, only paid 400 for it, its my first bike and im trying to figure out what the issue is with it.
It will try to start but won't fire up, Will have a couple backfires but will never completely turn over.
The guy i bought it from said he had it looked at by honda and 2 other places and they all said it was the carb floats sticking.
Fast forward to now, I took the seat and tank off and there was a hose not connected to a box, looked like a air box of some sort it had a filter in it running to the carbs, still not sure what it was. But anyway got down to the carbs and they were spotless clean, and opening fine with the throttle. I'm thinking maybe the spark plugs are bad the guy had it a year and never changed them so im gonna try to get some new plugs in tomorrow and see what happens but i wanted a second opinion, i don't think its the carbs cause they where getting gas, and when i tried to start with tank off you could smell the gas and saw it spitting. So im kinda stumped and looking what you guys think. Please help
![EEK!](https://cbrforum.com/forum/images/smilies/eek.gif)
you really can't tell if the carbs are clean just by sight. Having said that, try spraying some starting fluid or carb cleaner in the carbs and see how they fire then. if they do, then thats a pretty clear indicator the carbs are fouled.
also, it sounds as if the vacuum lines have been messed with. on the cover of the air box there should be a diagram of all your hoses. in addition if they are the original hoses they are numbered.
Not sure what the enrichment circle is I'm a noobie. But when I pulled my plugs should it spark in the rubber caps or down in the tubes my plugs are cause I tried firing it up,with the plugs loosened while looking into the rubber caps that go on top of the plugs and I didn't see a spark anywhere, I don't know if that's a problem or not.
