96 cbr 600 f3
I just got a 96 CBR 600 F3 from my brother and its got quite a few things that need work. When you put it in gear, with or without the clutch engaged, the bike stalls. I was wondering if anybody had any idea what it might be before I go ahead and replace the clutch.
Is the side stand down? There is a kill on the stand to prevent a pogo on a left turn.
Check the switch on the clutch lever, the side stand and the neutral sensor.
Replacing the clutch is not a likely solution.
Hope this helps, Ern
anyways check the electricals at your saide stand switch, and your clutch switch.
cant find the diagram after looking for 10 minutes so here is a quote
"You want to connect the green wire (ground) to the Green/White wire to tell the bike the stand is in the Up position all the time."
