600rr tail on an f3
Old Jan 3, 2010 | 02:39 AM
dsnow77846's Avatar
Default 600rr tail on an f3
how did people do that in the pic section?
Old Jan 3, 2010 | 04:07 AM
dsnow77846's Avatar
im thinking of just buying this but i dont know if it leaves room for a taillight
Old Jan 3, 2010 | 10:13 AM
orangef3's Avatar
600rr tail has to be adapted to fit using brackets or however you can come up with to attach it...i'm in the process of doing mine now...i bought all the necessary brackets and seat latches from ronayers to get mine to go on. that looks like a race tail...if you want to put a tail light in it you are going to have to cut the hole out
Old Jan 3, 2010 | 04:07 PM
dsnow77846's Avatar
can you take pics of your installing process?
Old Jan 3, 2010 | 04:32 PM
dsnow77846's Avatar
and also what brackets did u buy
Old Jan 3, 2010 | 06:01 PM
NYKnick1015's Avatar
since the 600rr subframe is bolt on, you can pretty much come up with your own idea. The f3 subframe is welded on u have to cut it and create your own
Old Jan 3, 2010 | 06:43 PM
willduce's Avatar
you also better have some decent fabrication skills if you want it to look good. not a bolt on by any means, alot of bull**** fab work to get it together right
Old Jan 3, 2010 | 07:23 PM
orangef3's Avatar
you're going to need the front and center cross plates. both seat hooks for the rear seat the seat release cable and a few misc. bolts...from there you are just going to have to get it all lined up and attached to your subframe whatever way you see fit. mine is at a co-workers since he has a welder in his garage and i don't so i'll get by there sometime this week when the rest of my parts show up for the rest of my conversion
Old Jan 4, 2010 | 12:44 AM
dsnow77846's Avatar
ima go with the airtech streamlining tail and just cut out the taillight
Old Jan 4, 2010 | 02:30 AM
dsnow77846's Avatar
this is what it would look like if i got the street tail what are your opinions
cds83
Jul 3, 2013 12:05 AM
teenbmxer
Dec 29, 2010 09:16 PM
pipedcbr
Oct 4, 2010 09:08 PM
Hootie233
Aug 25, 2010 03:08 PM
Rklamb16
Jun 12, 2008 01:58 PM
