600f f3 upgrades
That's a first for me. I haven't heard of this one. If you change the head, I can't imagine that the intake ports are in exactly the same place to mount the carbs, or the cam chain being perfectly aligned with the F3 crank sprocket. I guess it's possible. Not sure how many of the design features carried over from the F3 engine.
What year RR head had you heard about ?
Will it bolt right up? No. But I guess anything is possible if your going to spend the $$$. If $$$ is no object, then I would look into a set of cams & head work. A 636 is always an option on the F2 & F3. Your going to spend as much money on getting a RR head to work propperly, if at all, as you are doing other mods.
nope not done a thing to it yet its bein repainted only bought it a week ago but got a full system and filter to go on the day i bring it home plus needs valve clearances doin so was thinkin the new head would solve that ne but obviously not lolthanks for all ur info tho people
There are plenty of places that will professionally dyno tune bikes. You should look it up before doing anything drastic to the engine.
