4th cylinder running rich
Alright so on my 98 F3 I was taking a nice ride through the canyon. Well about midway through the ride I notice I have a cylinder misfire. I also notice a lack of power and response. I get her home and tear her apart and I notice I'm running extremely rich on cylinder 4. Thinking plug first I change that. It works for a bit and then is saturated again.
The carbs are out and all seem fine and within spec. Ever since I've gotten the bike I've never had the carbs synced but I have had them out numerous times. So I purchased a carbtune pro so I can. But my question is will syncing the carb effect how rich one cylinder is running?
Yes it can change the air/fuel ratio. Also sheck and see if you have an air leak at any connections for that cylinder, more air will provoke a rich condition to where it can flood itself out. If you have the carbs out check to see that your float is not stuck.
Since you said you have pulled the carbs i would suggest an air leak. The first time i pulled my carbs i didn't get them bck on just right and the bike ran like crap from an air leak. Check the boot that clamps the carbs to the block make sure those screws are snug. Double check all hoses are connected and have a free flowing route.
Update: So I got the carbtune in today and I was able to sync my carbs. It seems that the 4th cylinder was running 4 cmHg less then cylinder 3. So after getting that up into range she seems to be running very well. I also double checked for any vacuum leaks before I put it all back together and it seems to be all in order. Thanks everyone!
