2 Sets of Frame Sliders?
Old May 6, 2009 | 12:30 AM
jpanside@gmail.com's Avatar
Default 2 Sets of Frame Sliders?
4 total, 2 on each side?
I have never seen a bike with more than 2. I think i will try this. will this look ghey?
Old May 6, 2009 | 07:50 AM
Northernfirepower's Avatar
Your kidding right? Good luck with the swingarm bolt ...
Old May 7, 2009 | 10:46 AM
Michael S's Avatar
there is another mounting bolt just above the swing arm bolt. but i think it may be an extended bolt that goes through to the other side. so not sure if it'll work for you. but that'd be easier than the swing arm bolt.
Old May 7, 2009 | 05:48 PM
SIRR1's Avatar
The front engine mount is where I placed my frame sliders!
It's good location but you will need to drill a hole in each your lower fairings to mount the sliders...
It's a do or die modification to mount the sliders there, I pinched my *** cheeks together last month when I drilled holes in (brand new in the Honda Box) lower fairings for the F3.
The Swingarm bolt location might interfear with your legs when your riding the bike so I don't think I would put them there, plus getting the swingarm bolt out of a 13 year old motorcycle could be a bitch.
When you lay the bike over it's going to hit on the end of the handlebar for sure so you want the bar ends on, then your front sliders will protect the front plastic and then you need something farther back, maybe sliders for the rear axle.
sirr1
Old May 7, 2009 | 08:47 PM
thanks for all the advice. really appreciate the help bros
captain crash
May 17, 2010 06:30 PM
Roast
Apr 7, 2010 10:44 PM
01kwt2000
Aug 9, 2007 09:39 AM
