2 more problems
Old 05-11-2008 | 10:30 AM
eknerr's Avatar
Default 2 more problems
Problem 1: Does anybody know what might cause my front brakes to lock up after riding? It has only happend twice, but I dont know what might be causing it. When it happens I just open the bleeder valves and a little fluid comes out, and they unlock.
Problem 2: I tried adjusting my clutch so that it engages sooner, but I reached the end of the adjustment limits. Does this mean I should replace my clutch? It doesn't slip or anything, it just won't engage until the very end of the lever's travel.
Any helpwill bemuch appreciated!
Old 05-11-2008 | 10:36 AM
KidCr3nshaw's Avatar
Default RE: 2 more problems
Problem 1: air in your lines. Bleed them proper or have someone else do it... are they stainless?
Problem 2: The clutch has to places for adjustment, minro adjustment (handlebars), major adjustment (clutch cover). If both routes have been explored then a new clutch may be in your near future.
Old 05-11-2008 | 10:52 AM
eknerr's Avatar
The brake lines are stock. When bleeding them, should I start on the left or right side?
And yes, I tried both adjustments.
Thanks for your help KidCr3nshaw
Old 05-11-2008 | 02:38 PM
redzintimidator's Avatar
If its not air in the lines, you might be instore of a rebuild. The pistons may be too gunked up. Usually with air they just feel really soft.
Old 05-11-2008 | 02:43 PM
Mooseknuckle's Avatar
I would swap all the fluid out with new stuff, just to be on the safe side. It sounds like air in your lines.
How old is your clutch? Maybe a cable replacement?
Old 05-11-2008 | 04:40 PM
§T®ÈÈT¿ÐÈMOÑ's Avatar
if the brakes lock up and you open the bleeder screw and the unlock it sounds like you have a collapsed brake line thats holding pressure, i would recommend you replace them as it can be hard to tell if they are collapsed or not they have a inner hose and a outer hard rubber shell, sometimes you can pinch and bend the lines and watch for the calliper to release to verify its a line, but it does not always work
Old 05-11-2008 | 09:52 PM
Sproutf3's Avatar
Registered Users
there could be debris of some kind in your brake lines, https://cbrforum.com/m_566531/tm.htm
m21oliver
10-01-2018 10:52 AM
clintthec
07-27-2011 06:04 PM
honda23
06-28-2011 12:24 PM
cr cbr
11-28-2006 04:36 PM
Quick Reply: 2 more problems
