#2 cylinder is dead from a light fall, ran fine until this happen
A couple weeks ago, I dropped my bike. A little fall, basically just a tip over while the engine was running. Laying on it side the engine was still running until I tried to lift it up and the rear wheel touched the ground.
Once up, I tried to start it took awhile to restart it, but it did. I had a misfire, rode it home about a hour ride and it runs perfect at high speeds, nothing out of the ordinary.
Got home pulled each spark wire tested it for spark and it getting it to the plugs. Replace plugs with new ones and still have it.
Replace the coil and still have the no fire at #2.
Does this sounds like I am in need of a new engine?
Well I haven't rode it since, just started revved it high a couple of time and shut it off. Been doing that for a couple of weeks now, it still the same.
I check for a weak spark also, matter fact I think if I am not mistaking the test light was not as bright as the other, now that you meantion weak spark.
Thanks,
Thanks,
When my bike got dumped, oil got up on the spark plugs. Trust me, you may have to take them and clean them a few times. The oil seemed to never want to clear up. Eventually i got it running good. It would stutter low-end and then once it started revving higher it ran smooth. So just try and ride it out.
Jason
Jason
Hmmmm, no spark on #2 cylinder is not from a fouled plug or from oil or to much fuel and I don't think running the bike is going to fix your problem...
You have an electrical problem, a wire that has come loose or broken to the #2 coil when you dropped the bike.
You replaced the coil on #2 so you connected the 2 wires that run to that perticular coil.
Go to those 2 wires on the #2 coil and start tracking them down to their source and make sure there not bare and grounding, broke or not plugged into the wire harness.
You can take a volt meter and test your good coil wires with the bike running and then compare your results to the #2 coil wire to see what wire is not connected.
Check your plug wire and cap for good connection and if this help does not fix the problem I would look at the black box as possibly failed from being dropped.
It's kind of hard for me to give you any other advice since I don't have the bike in front of me, if it was my ride I would double check the coil wires to the harness, plug wires and cap then the black box.
Good Luck on this fix!
SIRR1
SIRR1
WhiteHawk
05-30-2013 09:56 PM
