1996 F3 front Fender mount
Old Sep 3, 2018 | 01:13 PM
sypherian's Avatar
Default 1996 F3 front Fender mount
Can any of you provide pictures of how you front fender is mounted on a 95 -96 F3?
Reason I ask is (I'm probably not gonna be able to explain this very well) that on one side of my bike the brake hose is mounted to the same place the inner most mounting hole for the fender is, but on the opposite side the brake hose is mounted a bit further up, is this how it is supposed to be or is it not meant to be that way. I bought the bike used obviously and there was no fender on, I finally found a seller and got it home but I just want to be 100% sure before i start mounting those two things at the same place.
Thanks in advance
Sypherian
Old Sep 5, 2018 | 10:56 AM
jalen11598's Avatar
Hello
I've changed my brake lines to steel braided but here is a diagram that will hopefully help you.
Old Sep 6, 2018 | 02:52 AM
sypherian's Avatar
Thank you this gave me the run down of how to assemble it all, much appreciated.
Sypherian
fugly62
How-To: Mechanical
Aug 28, 2008 04:25 PM
jayfab2g
Aug 16, 2008 06:40 PM
domon
May 7, 2008 09:27 PM
Scrufdog
Sep 26, 2007 02:55 PM
OLDBIKE
Mar 1, 2007 10:42 AM
