1996 F3 First gear speed?
I've always been concerned about my first gear speed. I can only reach about 30 mph (maybe 35) and then i have to shift into 2nd. The bike only seems to pull up to about 4500-5000 rpm, and then after that, it revs, but there isn't really a corresponding increase in speed.
Also, this happens in 2nd, though to a much lesser extent.
I've youtube vids of an F3 reaching about 90kmh in first, which i believe is about 55 or 60 mph.
Any ideas? All the other gears seem to be working fine.
Sounds like you have a higher gear ratio than stock.
Other than that, it might be that you're not accelerating after 4-5k RPM because the clutch is slipping. In that case, it will rev, but you won't go anywhere.
