1995 compression issues
Old Jul 11, 2022 | 08:26 AM
rc51fan's Avatar
Default 1995 compression issues
Purchased a 1995 f3 a few weeks ago. Actually brought a compression tester to the sale, but was unable to test (as I didn't realize these had a 10mm spark plug, So tiny!)
well, i got it home, I had low compression is all cylinders. (1-150, 2-50, 3-125, 4-150) so I did the valves. All of the intakes were very tight.
Valve job went well ans are not in specs. Compression jumped to 180psi in cylinder 1 and 4, but 2 is only 80psi and 3 is 145.
If I have to tear the case in half to bore these cylinders, is it even worth it!?
Old Jul 12, 2022 | 07:08 AM
I think it depends on a number of things. What is your goal with the bike? That low of compression seems like it wasn't very well maintained. What other things might be wrong with the engine? What would a known good replacement cost? Have you looked at the cylinder walls? How do they look? Maybe just bad rings.
Considering you can't use it as is, it probably doesn't hurt to split the case and see if there are any other expensive things to repair, like crankshaft bearing journals or others that would sway your decision one way or another.
Old Jul 13, 2022 | 10:09 AM
rc51fan's Avatar
Found a local guy who works on the older rockets. He said 90% of the time with these bikes, the valves "pull up" and gap. So I pulled the head and am having it looked at.
Cylinder walls looked perfect once I got in there luckily. Guess we'll hope and pray that the compression is saved once we get it back on.
Old Jul 13, 2022 | 12:11 PM
dannoxyz's Avatar
Could be carbon-buildup and clogged rings. Do hail-mary last attempt with piston-soak.
1. remove plugs,
2. spray 7-10s of PB-Blaster down each spark-plug hole
3. gently lay plug over hole and let sit for 2-3 hrs
4. add 2-3cc 50/50 acetone/ATF mix
5.gently lay plug over hole and let sit for 2-3 hrs let sit for 2-3 hrs
6. remove plugs, lay rag over opening
7. crank engine 5-10s to blow out excess fluid
8. re-test compression
I've brought lots of engines back this way due to clogged rings.
Old Jul 14, 2022 | 11:04 AM
rc51fan's Avatar
1. remove plugs,
hmm. Clogged rings. Alright. well, i have the heads off already, cylinder walls look good, and judging by how sticky some of the carbs were, I'll definitely soak the rings.
I've heard "marvel magic mystery oil" and "seafoam" work well too, I guess I forgot to try those options before taking the head off! Someone also mentioned a "leak down test" that I should have done. Someday I'll know everything, but it isn't today
Minimonkey94
Oct 13, 2021 02:41 PM
fernnny
Dec 20, 2014 11:50 AM
Akol47
Jun 30, 2012 08:15 PM
Weidenheft
Oct 12, 2009 09:51 AM
Bear600rr
Dec 10, 2008 07:23 PM
