1994 CBR Fork Issues
*** edit: it looks like F3 forks don't have this ball/spring set-up. But any advice on where I can find a circular spring is still appreciated! ***
Hey guys, I already posted this to the F2 forums, but since the 1994 F2 forks are similar (same?) as the F3 forks, I figured maybe one of you guys have run into a similar situation.
So I'm currently replacing a busted oil seal in my fork and while taking out all of the internals of one fork, I notice that the little spring loop that goes around a little ball bearing near the rebound dampening adjuster is busted. (the spring that wraps around right under the o-ring)
I believe this spring holds the ball bearing in place, and it provides that "click" feeling you get when you adjust the rebound dampening adjuster.
So after I put the busted spring away, i continue cleaning the dampening rod and i completely forget to store the ball bearing away in a safe place first! So i'm now missing both spring and ball bearing!
Does anyone know of a way to replace these two parts? It seems like it would be hard to get ahold of these small parts... I attached a photo of what the good part should look like, with an arrow pointing to the spring in particular.
Any advice would be greatly appreciated!!
SalemCBR
Nov 17, 2016 07:53 AM
civicblade
Apr 23, 2009 08:24 AM
