yay. boo. yay. boo. yay. boo. boo. boo.
Plugged the tire this morning after I got to ride to work in the rain. for now - my commuting is 6 miles each way in normal traffic. I'm not worried bout the plug at this point- but I do have a new tire on the way.
I used my mountainbike CO2 inflator to get the tire back up to pressure. I was seriously impressed with how well it did. Before I got the plug in and sealed up - the tire dropped to about 26psi. I used (3) 16gram CO2 cartridges thinking they weren't doing much. I checked the pressure and it was at 45psi. I was impressed cause I know it takes 2 to get a mountainbike tire up to pressure from dead flat, wasn't expecting a 20psi boost from 3 cartridges.
dont worry about the plug but when you do change the tire you can order one from rockymountainatv/mc...i got a 180 pilot powr from them for 98 shipped
thanks guys - got the truck back Thurs afternoon, and that evening took a good look at the balljoint problem I knew had been lingering on the pass. side for a while.
Lemme say this - don't procrastinate on required maintenance!!! Damn - I've cost myself more money that way. Balljoint had totally collapsed, and the swivel portion had broken through the top allowing my steering knuckle to ride directly on the a-arm.
Had to pull the whole front suspension out on that side and source a new steering knuckle on a Friday. Luckily a local U-pull-it place had one on a wreck that mercifully was only hanging by the upper balljoint - so I didn't have to do a teardown in the salvage yard. $24 and a new upper and lower balljoint and I'm back in business.
I'm keeping the punctured tire, just in case.
