Why???
Old Apr 9, 2009 | 02:21 AM
kray923's Avatar
Exclamation Why???
I blew a rod in my bike. Cold morning, started it up and let it worm up for like 15 minutes. I rode down the road and came to a stop. All I hear is like a piece of metal bouncing around and it is running like ****. I got home and drained the oil, I saw little pieces of metal in the oil so I took the oil pan off and there it was several big pieces from the push rod of the piston. I am going to drop the motor and either replace the whole motor or the piston (havent decided yet). I just want to why it happened so I dont go through this again.
Old Apr 9, 2009 | 07:35 AM
99LS1's Avatar
Wow, that totally sucks for you man! Im sorry to hear that. I can't answer your question but hope it all works out for you.
Maybe a 900 swap??
Old Apr 9, 2009 | 08:27 AM
Sand.Man's Avatar
Take a picture of the pieces you found in the oil pan, and a view of the crankshaft from the under side of the motor.
I find it hard to believe that the connecting rod blew apart on a stock motor, but you may be a first!
