View Poll Results: Does your f2 "pop" on overrun?
Yes
62.50%
No
12.50%
Sometimes
25.00%
Voters: 8. You may not vote on this poll
Whose F2 "pops" on overrun?
Old Sep 27, 2012 | 02:53 AM
RedBaron's Avatar
Default Whose F2 "pops" on overrun?
Just curious to see if anyone else's exhaust pops on overrun/deceleration.
My f2 has always done it, even when it had the stock exhaust and filter, & I cannot for the life of me find an exhaust leak so I figured it must be an f2 thing..
So does your F2 POP?
Old Sep 27, 2012 | 08:30 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Please define "overrun" - are you talking about bumping the rev limiter, or maybe high RPM deceleration?
Old Sep 27, 2012 | 12:13 PM
RedBaron's Avatar
Yes overrun as in deceleration or engine braking.
Old Oct 1, 2012 | 02:52 AM
RedBaron's Avatar
Guess it's just me.....that sucks
Old Oct 1, 2012 | 10:41 AM
squale147's Avatar
July 2013 ROTM
add some fuel to your pilot circuit and see if it helps..
Old Oct 1, 2012 | 11:40 AM
adrenalnjunky's Avatar
Mine does too. Never have gotten around to adjusting the pilot circuit.
Old Oct 2, 2012 | 02:54 AM
RedBaron's Avatar
Adjusting the mixture screws had no effect, slipping another washer under the needles also had no effect and I replaced crush gaskets on the headers to no avail.
I guess the only thing left is upping the pilot jets to 40?
Or should I go with a jk that has adjustable needles?
Old Oct 2, 2012 | 05:46 PM
squale147's Avatar
July 2013 ROTM
IF its happening at 0% throttle opening on decel it should be in the pilot circuit..upping the pilot jet from 38 to 40 might help but you should be able to tune it out with the 38s.. is the bike a cali spec by chance?
Old Oct 3, 2012 | 03:52 AM
RedBaron's Avatar
No squale not cali spec.
Old Oct 3, 2012 | 03:28 PM
squale147's Avatar
July 2013 ROTM
Assuming that the carbs are 100% clean and functioning properly you should be able to tune it out..if it is still popping on decel check your exhaust for leaks...thats the only other thing i could think of that could cause that issue..
