Who is spraying these 600s??
#21
If your internals arent made for the pressures N0S can add, it will go boom, or rather fry piston rings, pistons, or even bend connecting rods.
Go ask any drag racer how often their car gets tore down n rebuilt
#22
#25
Q: Will N20 affect engine reliability?
A: Theoretically not.
In moderate doses, properly set up and used by someone that understands the system then it should not have any adverse effects. In some cases the opposite could be argued.
But probably... One day its inevitable your engine will break, they almost all do so if you drive it like you hate it! No engine goes forever so just accept it! If it has N20 fitted it will inevitably get the blame!
And It may well be nothing to do with the nitrous and usually isn't!
http://www.nitrousdirect.com/nitrous.html
Again like I said "Used Right". Nitrous does not have a problem with anything its just a fuel and oxygen adder. With this running a good fuel mixture, right plugs, and a good working motor and not ripping on it will not hurt your motor. Btw look it up. A lot of sites will say it doesn't affect anything. It's all about who is using it but that can be said on how hard a person drives a stock bike..nothing last forever.
