What is the wire that goes to the clutch lever?
I had a look around the forum and couldn't find an answer to this question. What is the purpose of the wire that goes to the clutch lever? I assume it's some kind of switch or sensor but what does it do?
its a switch so you can start the bike in gear with the clutch lever pulled.
lulz it also tells you when your in neutral with the clutch in on the dash
You guys are lightning fast, thanks for the replies. I figured it was something along those lines but wasn't sure.
I asked because I have been thinking about buying new levers. If you replace the stock levers with after-market ones, do the after-market ones use the same bracket? Do you just replace the lever and it uses switch already on the bike? |
yessir, i just bought the shorty lever for my f2 it uses the same bracket just pull out the bolt and try not to break the bracket like i did lol
