What is needed to do a F4i fork install on a streetfighter?
Old Aug 23, 2010 | 11:08 AM
underground-mpyre's Avatar
Default What is needed to do a F4i fork install on a streetfighter?
I have a F2 streetfighter and want to do a F4i fork install.What exactly do I need to get to make it fit on my bike? I need better forks than what a F2 fork can give me.
Old Aug 23, 2010 | 12:04 PM
adrenalnjunky's Avatar
This is not an all-inclusive list. You'll need the whole front end, forks/wheel/brakes/triples/clipons. F2/F3 tubes are 41mm, F4 forks are 43mm. You'll probably need to figure out if the F4 or F2 head bearings are what you need - sure there's a thread around somewhere.
You'll also lose the factory speedo ability, with no way to get it working again.
The 94 model F2 fork was the 1st year they went to a real dampener cartridge with rebound control. If you got one of those it would bolt right up to your wheel/brakes etc.
F3 forks improved the rebound cartridge little, F3 uppers/internals will fit in your F2 lowers, so again you could keep your current wheel/brakes/clipons/speedo ability.
Throw some racetech goodies @ either setup and I bet it would be a pretty decent setup without all the guesswork.
Old Aug 23, 2010 | 01:38 PM
Already have a vapor speedo. I have Racetech springs and seals and seals went yesterday. I would like to get into road-coursing and bigger brakes are needed. I like the adjustabilty, but oem F2 forks don't cut it.
If anyone has done this swap, what all do I need different than forks, wheel, brakes and fender???
Old Aug 24, 2010 | 06:15 PM
Ok, how about this; Anyone ever installed a inverted fork on a F2? Which ones fit?
Old Aug 24, 2010 | 06:32 PM
*edit* - meant to add I'm not sure any inverted forks "fit" if you mean "fit in our 41mm triples'.
*edit the edit* - I didn't realize the late 90's GSX-R's were inverted - so there I go not knowing everything again.
I've heard of several years of GSX-R or SV 650 forks fitting in our 41mm triples - Vortex says their 41mm clip ons fit the following:
Honda:
'91 to '98 CBR600F2/F3, '06 to '07 EX650R, '88 to '90 NT650 Hawk, '90 to '97 VFR750, '92 to '96 CBR1000, '98 to '02 VTR1000/Superhawk, and '89 to '90 CB1.
Kawasaki:
'90 to '97 ZX6/R, '06 to '08 Ninja 650R, and '88 to '90 ZX10.
Suzuki:
All GSF400/600 Bandit, '88 to '97 GSXR600/750/1100, '99 to '07 SV650, and '86 to '87 GSX750/1100.
Yamaha:
'94 to '95 YZF600, and '87 to '88 FZR750/1000.
Of those, it looks like the Suzuki forks might be your best bets for performance and tuning ability.
Old Aug 25, 2010 | 10:47 AM
Thanks man! That is awesome. How do you go about knowing which headset/Races bearings to go with to fit the Mid 90's GSXR Triple to the F2? I know it can't be that easy.
Old Sep 9, 2010 | 12:04 PM
STREETFIGHTER88's Avatar
I got F4 Forks on my F2 You needed EVERYTHING
Forks, Wheel, Disks, Calipers, Yokes, clipons etc but the bearings in the neck are the same on a F2 and F4
you can just see the forks in my photos this is my F2
gregtutch
Apr 26, 2009 03:20 PM
kurcse
May 26, 2008 08:26 PM
CBR600F397
Mar 8, 2008 07:37 AM
BK600
Oct 9, 2007 04:38 PM
fakemeoutrepsol
Apr 1, 2007 05:17 PM
