Universal Speedo ???
Old Oct 22, 2009 | 02:11 AM
Fearless4x4's Avatar
Official Welcome Crew Redneck
Default Universal Speedo ???
I just purchased a universal speedometer with a magnetic pickup/sending unit. was curious if anyone else has/had one and how they installed it.
included instructions just give minimum tolerances to work properly, doesnt say where/how to install
any info or insight is appreciated
-sparks-
Old Oct 22, 2009 | 05:32 PM
Michael S's Avatar
Brand name? Model?
Old Oct 22, 2009 | 08:55 PM
halffast1g's Avatar
Let me know if you figure this out, as my speedo has gone to **** too. I am in tempe if you ever want to ride
Old Oct 23, 2009 | 01:44 PM
I is an Acewell Computer, Model number ACE-27xx/28xx Series
here is a link to an exact copy of the instructions i have:
http://www.acewell-meter.com/images/...-28XX-ENV3.pdf
any help is appreciated
-sparks-
Old Oct 23, 2009 | 02:57 PM
HenryM's Avatar
Is this like the kind of thing you fit to a bicycle? If it is, you need to calibrate it to tell it how far you go with every wheel revolution or better still how far you with every ten or hundred revs of the wheel, which ever one you're fitting it to.
Old Oct 23, 2009 | 04:32 PM
corwine123's Avatar
That sounds a lot like the vapor digital gauges I had on my bike. You can mount the pick up on your front fork leg with the magnet glued to the rim. Or run the wire down the whole back and mount the pickup on the inside of your swing arm, with the magnet glued to your sprocket. I found the latter to be much nicer looking (hidden) and more accurate.
Old Oct 23, 2009 | 05:12 PM
NYKnick1015's Avatar
i was looking into this today because i hate how big and bulky my analog gauges are on my f3... tell me how it works... i might pick one up my self
Old Oct 23, 2009 | 10:24 PM
Michael S's Avatar
Why not just do the f4i gauges? I did it on my F3. Are the F2's any different?
Old Oct 24, 2009 | 02:07 AM
the instructions have preset wheel sizes to programed into it. didnt have much time to mess with it today, however it will have to go on the front wheel because the wire isnt long enough to travel to rear end. will investigate more tommorrow.
RE: F4i guages, not sure how big they are but the problem with mounting stock sized gauges is my bike has 06 plastics and the stock f2 gauges wont fit in front fairing. the one i picked up is just one small circular guage that would fit nice when i figure out how the hell to get all functions working properly.... now having a hard time getting RPM to read correctly will report back tommorrow when i have a chance to troubleshoot somemore...
thanks again,
-sparks-
Old Oct 24, 2009 | 11:58 AM
kingyeddi's Avatar
is it just me or does that thing have an rpm gauge?? where did you get it from and how much did it cost??
