Turn signal wiring help??
Trying to finish up my streetfighter F2 project. I thought I found the wiring for the front signals,but now I'm not sure. Does anyone have a picture or color of wires I should be looking for?
Best I can tell you is, my 98 uses orange/orange white (left) and blue/blue white (right) and a green ground on each.
I'm saying that from memory, so the left/right MAY be back-wards. ;-) Again, this is from memory, but I believe the solid color is the turn signal and the color/white is the cruise lights. Ern |
Well at least that tells me its a 3 wire setup.
Originally Posted by MadHattr059
(Post 1058966)
Ok,so all the aftermarket signals I'm seeing are 2 wire. How would I wire these??
for the fronts - you can go just 2 wire and lose the running/parking light functionality.
or if you want to make them work as park/running + blinker in front you'll need to add a diode in - follow this how-to: https://cbrforum.com/forum/how-mecha...-inputs-84998/ |
Don't limit yourself to just cbr searches for lighting accesories. I found a pair of kz500 flush-mounts for the front of mine with the double-element sockets and three wire hook-up.
Ern |
(Post 1060021)
Ern |
