throttle handle sticks
Maybe the cables aren't connected correctly? Both need to be properly connected for the throttle to work smoothly.
If you have the carbs off, you should be able to tell if the spring is still strong by manually rotating where the cables connect to. How do you know the cables move just fine? You can connect them to the carbs and do the test while the air box and tank are still off.
Bret
I think it's the way the cables are connected to the carbs. When you roll on the throttle, the cable that is being pulled should be on top and the other at the bottom (with the carbs seated on the engine). Do the cable housings get crimped when being routed to the carb? When the carbs are disconnected and you manually pull on the cables, do they still move freely when you twist the throttle?
Can you take pictures?
I hit the cables with some WD-40 and the springs on the carb with some carb cleaner and then compressed air, re-installed and it now snaps back like it should. Not sure which one did it but not really worried about it at this point. Just wanted to follow up with what I did and if it worked. Thanks for the help!
Bret
Bret
FWIW, the Clymer manual actually indicates the cables can be lubed w/ motor oil. take the cables, hang them up suspended from one end. Cut the corner out of 2 ziploc bags and insert the end of one cable into the hole on each. Use a rubber band or tape or whatever to seal the bag around the cable, and then pour motor oil into the bags & seal em up. The bags will act like an I.V. bag, and the oil will seep down the line and out the other end. Have a catch pan underneath for it to drain into. do this till you feel your cables are properly de-gunked and drained, and reinstall.
