Taking bike to shop
Old Jul 27, 2007 | 09:40 PM
dawoonj's Avatar
Default Taking bike to shop
I'm taking my bike into a shop tomorrow and I wanted to know if I should tell them to look at anything in particular.
I just bought it a couple of weeks ago. I rode it sunday and when I went to put it up, it ran a little rough. Sounded like the bike was weezing. (If that makes sense.) But it went away when I hit the throttle.
I plan on getting a tune-up and having him check the chain cam tensioner.
Any other suggestions???
Old Jul 27, 2007 | 10:19 PM
cloudbreakmd's Avatar
Default RE: Taking bike to shop
Sounds like the carbs are dirty.
Old Jul 27, 2007 | 10:20 PM
Any other symptoms?
Old Jul 28, 2007 | 10:02 AM
dawoonj's Avatar
Just runs rough a little. But when I was on it, acceleration and the sound was great.
Old Jul 28, 2007 | 01:49 PM
dawoonj's Avatar
Just came back from the shop and I got bad news!![:@][:@][:@][:@]
I need a new engine. There is a thrown rod or piston of some sort. Bottom line the engine would have to be completely taken apart. The piece that had the problem goes around the crank shaft. Bear with me because I am a newbie here. So, all my terminology might not be correct.
Can anyone help me find a new engine. I got a 94 F2??? The guy at the shop said I might be able to get a F4i fuel injected engine is I got all the hoses and injectors. He said it would cost a pretty penny!
Old Jul 29, 2007 | 11:56 PM
Get a second opinion or make a video with sound and post it here. That sounds a little far fetched. Did he pull the oil pan off to inspect the lower half of the motor?
Old Jul 30, 2007 | 11:15 AM
dawoonj's Avatar
He didn't take the oil pan off. As soon as I started the bke up, the noise started. It wasn't happening until after I got to the shop and started my bike back up. I'm going to see if I can make a audio clip with my cell.
Old Jul 30, 2007 | 09:37 PM
dawoonj's Avatar
Here's a clip. Tell me what you hear.
http://video.google.com/videoplay?do...amp;pr=goog-sl
Old Jul 31, 2007 | 12:34 AM
BlkF2's Avatar
sounds like a cct to me.. search for the link on here for the "how to " on converting you stock cct to a manual cct.. very cheap and it is a common issue. Good luck
Old Jul 31, 2007 | 02:09 AM
Or if you want the OEM auto tensioner with gasket PM me (BRAND NEW and very easy to put on).
