Stuttering with constant speed
It's like a 15x5 sheet of rubber. Maybe as thick as 15 pages of paper. Tucks in between your head and your airbox\coils.
If you have to move a rubber flap to see your coils, then you have it.
To be more specific, if you have to move a rubber flap to see coils from above the bike with the tank and airbox off. The flap covers nothing from the side door. I just mention this because the way you worded this johnny made me think "well I can still see the coils from the side..."
edit: I said this wrong, I meant if you have to move a rubber flap to see the spark wires... not coils. Rubber goes between coils and wires... blahblahblah
I also have this problem too with my F2. It stutters at constant speed and doesn't ride smoothly. It happens after i release the throttle and let it cruise. it gets really bad between 1-5rpm. But the difference with my problem is that when it stutters i hear a popping sound (as if you pulled a suction cup off the ground). My guess it came from my carburetor diaphragm (the 4 rubber pieces on the top of the carb that has the needle. (http://img232.imageshack.us/i/diaphragm1in5.jpg/)
Do you think if there was some air leak in there, it would also cause stuttering problems? I think some carb cleaner mightve gotten into these diaphragms during cleaning and it might've deteriorated the rubber...
I think it's mostly solved now.
First I think the bougie witch we checked, was too loose in the engine.
Second I clean the carbs with some chemical stuff, without disambling
I used this: http://www.forte-nwe.com/EN/Forte+pr...o+Power+I.html
Translated with babel fish: ( not really a succes )
Forté Moto Power I are a complex mixture of especially selected solvents in combination with oppervlakte-actieve substances and binders. It solves amputations already formed in fuel systems. At use according to regulation in the tank of an engine bicycle Forté Moto Power I offer the following advantages: * The reiniging of the tank, fuel tap, carburetors and the complete injection system looks after. * Removes amputations of adjutages, amount openingamount openings and injectornaalden. * Delicate, varnish and resin solve in the whole fuel system. * Stabilises the fuels mixed with alcohol. * Neutralises heartburns which are formed ageing and oxidatie of the fuel. * The fuel consumption reduces and improves the engine performances. Forté Moto Power I are with all types petrol compatible, including petrol provide with synthetic components. Use Forté Moto Power I at service turns to keep clean the fuel system and as symptoms indicates that treatment is necessary. The product contains no substances and causes no impact as a result of which the guarantee of the manufacturer can expire come.
