Shiny Rotors
Old Oct 1, 2009 | 04:45 PM
Preid's Avatar
Default Shiny Rotors
My front rotors are becoming more mirror-like as the weeks go by. I wish to improve them but im flat broke at the moment (student). I do almost 300 miles a week on my bike fyi. I also use the rear brake alot aswel now to aid slowing.
I bled the brakes but didnt notice much of a difference. Had the idea of taking sandpaper to the rotors to try take off some of the shine. I didnt know if that would make the braking worse so here I am asking.
I dont ride fast and I also brake a long way from junctions if I can. Im trying to get the MPG past 60 (getting 55mpg atm).
Old Oct 1, 2009 | 08:21 PM
halffast1g's Avatar
I'm in the same boat. I am just gonna use 220 grit sand paper to rough up the rotors as needed
Old Oct 1, 2009 | 10:48 PM
Sand.Man's Avatar
Scuff the rotors with sandpaper (both sides) and if your pads still have life left in them, gently scuff them also, or just replace.
Be sure to "bed in" new pads properly.
Old Oct 1, 2009 | 11:04 PM
halffast1g's Avatar
I just purchased some new ebc double H pads, and will be sanding the rotors, I will let you know how it turns out
Old Oct 2, 2009 | 09:56 AM
Preid's Avatar
Cheers for the replies, ill sand them over the weekend. The pads have alot of life left so Ill give them a quick scuff aswel.
Old Oct 2, 2009 | 09:09 PM
Sand.Man's Avatar
When scuffing the pads, lay your sandpaper down on something flat and rub the pads in a figure 8 motion on the paper rather than holding the pads and scuffing them in the air by hand.
This just ensures that the surface will be sanded evenly.
Old Oct 3, 2009 | 09:33 AM
halffast1g's Avatar
My pads still had usable life on them, so I will be holding on my new pads until I replace the rotors/pads together. I sanded the rotors and bled the brakes, works like a champ
Old Oct 3, 2009 | 03:36 PM
Sand.Man's Avatar
Why replace the rotors? Unless they are worn down below spec, or have massive gouges in them you don't need to replace them.
Stock rotors should last forever.
Nicholas Scalisi
Rides
May 20, 2014 05:17 AM
RhysIoM
May 13, 2013 11:05 AM
jpanside@gmail.com
Mar 8, 2011 08:15 AM
Big Gaz
Apr 19, 2007 05:42 PM
kmetz33
Mar 22, 2006 07:49 PM
