Remove chain without breaking old or new?
Old Sep 25, 2012 | 09:02 PM
MaikuMizu's Avatar
Default Remove chain without breaking old or new?
I assume I need to pull the swing arm off to do it, right?
Old Sep 25, 2012 | 09:06 PM
gotcbr's Avatar
To remove the old chain, you can either grind off the flared master-link pins & remove the master link & the chain will be apart...or simply take your dremel & cut the chain apart.
Then install a new chain using proper chain tool kit. The master-link pins will have to be flared to factory spec for safety.
Old Sep 25, 2012 | 10:22 PM
Dirtrider009's Avatar
the new isnt put together, and the old one has to be cut/masterlink flares grinded, or clip removed. Removing the swing arm wont do it.
Old Sep 26, 2012 | 12:16 AM
MaikuMizu's Avatar
Old one is uncut and OEM
the new one is a used OEM one that is uncut. back tire is removed. need to do this without taking the chain apart.
Old Sep 26, 2012 | 08:24 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Remember in the movie Zoolander, when Owen Wilson's character Hansel, removed his underwear without taking off his pants? Well, if you can do THAT, then you can make this happen!! LOL. Anyway, you will definitely have to remove the swingarm.
Old Sep 26, 2012 | 12:02 PM
adrenalnjunky's Avatar
It can be done with removing the swingarm:
Old Sep 26, 2012 | 12:05 PM
gotcbr's Avatar
Read posts #'s 2 & 3.
Old Sep 26, 2012 | 05:07 PM
wes 17's Avatar
If it was me...I would exchange for a split chain, split the old one on the bike, join them, pull the new one through using the old. Fit split link. A 20min job instead of what could be a can of worms. When was the last time the swing arm bearings were changed, they could end up all over the garage floor etc. That could be for starters. Its up to you I know, the above scenareo is what would happen to me. Best of luck however you do it mate !
Old Sep 26, 2012 | 05:11 PM
UalRamper's Avatar
Muppet of the month August 2012 ROTM
Cut old chain off............then cut a link out the replacement and install a master link as described in an earlier post.
Change time 30 minutes, take off swing arm will equal several hours providing you have the special tools to take the nut off
Good luck Chuck
Old Sep 26, 2012 | 05:50 PM
He stated two things that some are missing.
A. The new chain is not new. It is used. I wouldn't introduce a new master link to a chain that might already have some stretch in it. Plus why buy the master link when u don't need to?
B. He already has the rear wheel off the bike. Swing arm doesn't require anything special to remove. One bolt on the shock. One bolt on the pivot. Would take 10 extra minutes, tops.
