putting a new set of front brake on
Old 02-03-2010, 12:23 AM
jnicola's Avatar
Be sure to bleed the furthest side first, then the closest, just like on a car
Old 02-03-2010, 10:35 AM
Project96's Avatar
You still have air in the lines. Try squeezing the lever & bleeding the master cylinder. Squeeze the lever & loosen the bolt that holds the line to the master cylinder. Just loosen the banjo bolt. Tighten the bolt before you let the lever go. Do it a couple times to make sure all the air is out.
When you are bleeding the calipers just make sure you close the bleeder valve before you let go of the lever. Otherwise you will suck air back in the line. If you do that you dont have to submerge the line in fluid.
Old 02-04-2010, 06:56 PM
halffast1g's Avatar
you get this worked out?
Old 02-07-2010, 07:09 PM
cyrusyn's Avatar
Thank you very much guys.
Now I can't not bring the end of the brake lever meet the throttle grip by squeezing with one hand.
lhsummit890
06-20-2010 09:38 PM
mike09touring
06-03-2010 01:57 PM
itsgroll
04-22-2010 01:44 AM
2full2ride
10-30-2008 01:13 AM
ocf4
05-26-2007 05:34 PM
Quick Reply: putting a new set of front brake on
