Project GOOF! - Honda CBR 600 F2/FM
No the bike was mine before that, I've owned the bike for around three years but unfortunately never had it on the road at all last year. I haven't used any sort of fuel stabiliser at all, just standard petrol (or gas) with the fuel tap positioned off.
Form what I can remember the bike ran ok except from a noisy CCT. I'm at a stage where it wold (or should) be easy enough to remove the carbs as I have almost removed everything from the bike. I just wouldn't want to bite off more than I could chew and begin messing with the jets and fuelling etc.
Also, with regards to the pilot screws, if you're running an OEM or OEM-type paper air filter, and have stock exhaust, then the pilot screw positions wouldn't necessrarily need to be recorded, as you could just set them at the OEM spec when you're finished... for all you know the screw for each of the four carbs may be set incorrectly, and/or inconsistently from carb to carb.
At any rate, with non-stabilized fuel sitting for that long in the carb bowls, fueling circuits, and even at the petcock screen, it is highly probable that things won't run as good as they could, without giving these items the old "once over".
Great looking bike Steven. It's great to get under the plastics and really learn what's going on with your bike. Looks like yours is in pretty good condition and just needs a bit of tlc and a clean.
Is the engine running nice and smooth? Any flat spots with the throttle? If everything is fine then you might want to leave the carbs alone. Having said that, it's not that difficult to do the basic overhaul if you feel like making sure they are clean. Definitely easier with a manual to follow, like a Haynes, as mentioned.
A couple of times I have rented a car in Inverness and driven across to Lochcarron on the West coast. Some lovely roads up there and the traffic is pretty light. You just have to watch out though because some of those roads turn into single lane tracks before you know it!
Without a doubt, if you're not comfortable working with the carbs, then you might have to utilize someone you trust, to do this. But, honestly, it's really not that hard, if your careful with noting where everything was, by recording the amount of "turns-out" the pilot screws are, properly labeling the various hoses and cables, and working on a table, where you can lay out the jet components in an easy to sort fashion, so that after you clean everything, you can get it back together correctly... pictures could help with that too.
The last time I ran the bike was 12months ago - maybe slightly more - and as far as I can remember it ran fine. I have a Haynes and Service manual which I could use to help me with the carbs if I decided to go that far.
Yea? Your right! There are some beautiful roads up there but unfortunately they aren't all well maintained. They are fine for a car, but winter just brings roads full of potholes.
I managed to get a little more work done on the bike tonight. I fitted new seals to the front clipers, re-greased them fitted them on with my new braided lines. I also picked up my valve cover bolt from honda, refitted that - without snapping any bolts! - then cleaned and re-installed the spark plugs.
I also received a rear caliper which I bought on eBay but the piston is well and truely stuck. I'll have a go at removing it on Friday/Saturday.
Looking forward to next month in order to purchase some new items for the bike. Plans are
New leavers (possibly shortened style) - http://www.ebay.co.uk/itm/2209864299...84.m1423.l2649
Black grips, possibly these: Adjustable CNC Clutch Brake Levers For BMW K1200S 04-08 | eBay
And a double bubble screen as well as a far maintenance items. I'm not entirely sure which colour of screen would suit best, I was thinking clear or lightly smoked.
...sorry Steven, just giving you grief!! You KNOW that it HAD to be done!!
New leavers (possibly shortened style) - CNC Brake Clutch Levers Honda CBR 600 F2 F3 F4 F4i 91 92 93 94 95 96 97 98 99-07 | eBay
I would leave the OEM levers, but I'm already sooo used to my CRG's, that I don't want to give up that adjustability while riding, and I want to keep as much consistency as possible from bike to bike.
My maiden voyage on the new streetbike was last night, just after 11:30pm, and I rode to work this morning, and there is a lot of difference in the "feel" of the new bike, compared to the other one, which makes since, since it's got different levers, different rearsets, different gearing, different tires, stock brakes vs. highly modified, and is about 30 pounds heavier to boot!
By the way, you mentioned some grips, but the link after that was another link to some CNC levers... you probably didn't notice when you posted.
The reason I'm going with a Hong Kong screen, is because though there used to be multiple racing brands, with offerings for the F2, I have had no luck finding anything... I did find this site, they are German, and I'm betting the product is higher quality than what I'm currently considering, and, they have 4 different aerodynamic styles, in addition to 4 different finishes, to choose from. But, they are pricey, and the cost is prohibitive for me at this point - $106 USD / £ 69 - that is before shipping costs.
https://www.mrashop.de/erp/catalog/n...N_KEY.offset=0
I wouldn't use these on my race bike, but, the truth is, one of these essentially "brandless", super-cheap CNC lever sets are going on my streetbike too... considering the OEM levers are basically "pot metal", I'm sure these will do the job just fine.
I'm giving in and getting a cheap Hong Kong double-bubble for the race bike, as the Zero Gravity screen is too low profile for the track, even lower than OEM. What I've noticed with those Hong Kong screens, is that if the screen is smoked, it's VERY dark smoked! Obviously, I want clear for the track, and I think clear would look the best on your bike, in MY opinion, but honestly, a light smoke would look good too.
I'm currently watching a clear double bubble on eBay at the moment. It's £18 delivered from Hong Kong which is a bargin. The more expensive one - probably better quality - tend to retail for around £60-70. Anyway, they have 4 available so if you are interested, I can send you the link.
I think I might tackle the carbs once I've got all the minor jobs out of the way. To he honest, the only thing that is worrying me is removing and installing the throttle cable from the carbs. How difficult actually is it to remove and re-install?
You'll slacken the cables by using 10mm open-end wrenches (having two is helpful), at the carb side, and then use your fingers to manually open the butteflies using the assembly containing the return spring, so that you can manipulate the actual cable and work the cable end out of it's channel, then get the other one out - I usually loosen all the motor-side clamps on the boots, and actually get the carbs free from the motor before I disconnect the cables.
Truth is, the most frustrating parts of removing/re-installing the carbs, is getting them free from the motor, and then getting the cable ends back in their channels... it's NOT hard as far as understanding, it's just one of those things that can make you do some cussing until you get it!!
Once you get the cables back in their respective channels, and restore the metal bosses at the end of the cables casing, to their respective clamps, you just get the adjuster nuts tightened to where the cables are going to stay put, AND when you twist the throttle, you get wide-open throttle, and full return, before actually remounting the carbs to the motor.
Most of this won't make too much sense, until you see it!
