One Great Summer
Well, as the saying goes, there's no replacement for displacement, so the obvious would be to punch out the cylinders to 66mm, for a total displacement of 618cc, or to 67mm, for 637cc (stock is 65mm) - this will of course require oversize pistons and rings, which will probably run between $700 and $900 (U.S. Dollars).
Another popular option is to replace your exhaust cam with your intake cam, and procure an F4i intake cam to run as your intake cam - if I did this, I would probably get slotted cam sprockets while I was at it.. bear in mind that with increased displacement and bigger cams, you'll need more fuel, so bigger mains, higher position needles, and larger pilot jets would probably be needed as well.
...there's something missing, the L22221 would be the top stamping on the crank weight, but there's a character missing form what you posted for the bottom stamping - you've got "LAAA", but there should be another character, check that again.
The 1 is the key, but, regarding your earlier post:
Ok thanks. What about the cam lobes on the f4i are they in same position? Also is the f4i the same thickness as the f2 and fit in the caps?
I have rebuilt many engines in the past, and I'm not going to tell you that it's rocket science, but it's a helluva lot more comprehensive than just bolting on parts, so if you don't have any engine building experience, I recommend a lot of research first, or at least using a good manual and working very cautiously.
Chances are, you'll do fine, if you've got good mechanical inclination, and truly understand how a motor's components work together, but I'm just saying... proceed with caution!
By the way, I mentioned the F4i cam swap because I know that it's one of the popular options, but you can also get aftermarket cams that are hotter than stock - you just have to see what's available.
Im ok with building engines i have worked on toyota drag cars in the past and have rebuilt 3L N/A converted to single turbo producing 1400 bhp using forums and help with a good engineer which sadly isnt around. So i have knowledge and experience just not on the motorcycle side. I am doing loads of research. I just thought at the stage im in, would be an idea to find out weather to leave it stock and jet it or change internals whilst its apart. When you say about other aftermarket parts, where is the best place to look? Ok im not technical but i can learn and read into what im doing first.
Anyway, blah, blah, blah, you can figure that out.
With regards to where to look for aftermarket pistons/cams, the first places that come to mind are OrientExpressRacing, and CBRZone - check out their sites.
If the internals are stock, I wouldn't spend any money/time on re-jetting, unless you have a race header and/or hi-flow air filter... if you're only running a slip-on, and have an OEM-type paper air filter, then there's really no need.
