Oil change
Old Jan 5, 2012 | 02:53 AM
blacken77's Avatar
Default Oil change
Im going to do a oil change but dont now what kind of oil i want to use
so tell me what you use....
i did one last summer but i do not like the oil i used
AMSOIL SAE 10W-40 Synthetic Motorcycle Oil
i think its to thin so i looking for something other then that to put in my bike
Old Jan 5, 2012 | 10:52 AM
Wranghondo's Avatar
Personally, I believe people put too much importance on what oil to put in their bikes and not enough importance on how often they change their oil.
Synthetics are fine if you don't mind paying twice as much for the same amount of protection for the amount of time the oil is in your crankcase. If you want to go 15,000 mi. between oil changes then I'd recommend synthetic.
Your best bet is to run the slippery stuff in the plastic bottles and change your oil every 3K mi. or less. The only thing I'd warn against is paraffin based oils like Shaffer's. JMHO & YMMV.
Old Jan 5, 2012 | 02:53 PM
switched's Avatar
I use synthetic Rotella-T (T6, it's a blue bottle) that you can find at Walmart. Every resource I've found online says it's pretty good stuff.
Old Jan 5, 2012 | 04:22 PM
estate4life's Avatar
February 2012 ROTM
If 10W is thin, you can try 20W....synthetic or not, don't think it's good for the bike running too many hard miles between oil change.
I would say follow your owners manual specification.
Using Amsoil or Royal Purple makes us more handsome then chicks will be hitting on us.
Using Semi Synthetic will get us the job or a pay raise.
Using conventional, girlfriend will love you more, since your are spending less on bike, more on her..
JK...
Old Jan 5, 2012 | 07:49 PM
JankCibberf2's Avatar
i use semi synthetic, synthetic is way to thin for our old bikes. ****, they didn't have synthetic when this bike came out so why put it in now
Old Jan 26, 2012 | 09:32 PM
ryans93honda's Avatar
My bike is lubbed my grape jelly! Royal Purple! I still change my oil and filter every year!
Old Jan 26, 2012 | 10:34 PM
Project96's Avatar
Motorcycle oil needs to be utilized here. Car oils have pariffins in them that can mess up the clutch in bikes. 10W-40 is recommended whether you use synthetic or not. You will need about 4.5 qts & a filter.
Old Jan 27, 2012 | 12:08 PM
adrenalnjunky's Avatar
Rotella T6 here for the last several oil changes. Found a deal on 3 gallons for $18 once, so I stocked up. I use Wix filters for the Nissan VQ35 3.5L V6 (350Z, Altima, Maxima etc...)
Old Jan 28, 2012 | 08:21 AM
Wranghondo's Avatar
Here's a link to some info on the T6.
http://www-static.shell.com/static/c...rotella_t6.pdf
Old Jan 28, 2012 | 10:47 AM
blacken77's Avatar
i dont see any where it says it works on bike clutch
