OEM Sprockets
Old Oct 18, 2008 | 08:55 AM
DRLOWZ's Avatar
Default OEM Sprockets
Ok as you all know I am a newbie so clown if you wish....lol...but anyways what is the OEM sprocket sizes on the 93? I want to go to all stock stuff since the bike I purchased is pieced together... also what chain do you all recommend and is this a do it yourselfer type job?
Thanks again..
Dennis
Old Oct 18, 2008 | 12:38 PM
lakaiguy's Avatar
Default RE: OEM Sprockets
stock size is 15 tooth front 45 toth rear
and for chains stick wither DID or RK
and yes if youre familiar with the bike you can DIY
Old Oct 18, 2008 | 12:43 PM
DRLOWZ's Avatar
Right now it has a 43T in rear.. I havent checked the front yet...when I ask for a chain, what is the difference between O ring chain and non O ring chain.. Why would it have a 43 t in rear?
Old Oct 18, 2008 | 07:50 PM
MikeInCtown's Avatar
15/43 Is stock on my 92. (91-94 actually) The 45 would be the +2 that a lot of people do for acceleration. IMHO, unless you are racing from light to light you do not need it.
530 o-ring chain is OE. They are pretty hefty chains and there are lots of chains out there. When I got my bike last summer I replaced the chain and sprockets. Bought a $99 eBay special and have put nearly 10,000 miles on the bike since then. The chain they sent me was a KMC chain with a clip link and I haven't had a problem. I know some people say they are dangerous. if they were that dangerous then they wouldn't be sold IMHO. Those clips clip in tight and if installed properly they should never come loose.
Old Oct 19, 2008 | 04:25 AM
nabobblaster's Avatar
If you want to free up some horse power swap to a 520 conversion setup.Get the kit it saves the hassle of finding seperate parts.The 520 setup is really strong.And it looks better without the log chain.
Old Oct 19, 2008 | 09:03 AM
DRLOWZ's Avatar
So my best bet is to go to a 15 front 43 rear with a 530 O ring chain...now do I need any special tool to get the clip on the chain?
Old Oct 19, 2008 | 12:49 PM
Hurricane rider's Avatar
a chain breaker/rivet spinner tool, like the one Motion Pro sells would very likely help you make installing the chain much simpler. I trust the 530 chain a LOT more than a 520 on the CBR, 520 just looks sooo flimsy in comparison. not really a chain I'd like to own/run.
Old Oct 19, 2008 | 01:05 PM
DRLOWZ's Avatar
But can you get the chain on without that tool??
Old Oct 19, 2008 | 01:58 PM
powerban's Avatar
You can take the chain off without a tool. All you need is a dremel. You will need some kind of chain press to install the new chain. The 520 setup will be MUCH cheaper since there is less material you're getting. its also a LOT lighter. Even if you keep the same gearing ratio, you'll feel a SLIGHT bump in acceleration by just using a 520 setup. The 520 setup is pretty reliable especially on the F2/F3. It doesnt make enough power to break a 520 chain.
Old Oct 19, 2008 | 02:26 PM
thrasher572's Avatar
I used the 520 conversion on a motorcycle with 50 more horsepower than the old CBR and it is holding up well. If you buy the chain breaker kit it usually has the riveter as well so no masterlink with a clipis required.
