noise when cold
Old Mar 3, 2011 | 11:17 AM
ldgriffin's Avatar
Default noise when cold
So my bike (94cbr600f2) makes kind of a rattle when its cold. I had it in the shop awhile ago and the guy mentioned something about the oil pressure needs to get up and the noise will go away. I've read some posts about the cct, is this related to that? im kinda mechanically challenged. just wondering if this is an easy fix or does it even need to be fixed?? thoughts?
Old Mar 3, 2011 | 11:32 AM
Joe 96 CBR F3's Avatar
Default I'm no expert
I'm no expert but I would guess the CCT. Check the right side of the engine to see if the rattle is coming from there. Use a wooden rod of some sort, I used a broom stick when I did this, and place it on the engine in different spots. If you put your ear up to the rod you can hear the rattle much better. Try to find where it is the loudest, if its the loudest on the right side of the engine I would say it is the CCT. Thats what was wrong on my F3. Good luck.
Old Mar 3, 2011 | 11:34 AM
Dissevered's Avatar
most likely it is your CCT, and its an extremely easy fix. If you know how to screw and unscrew bolts, and put sealant on a gasket, and have an hour to tinker, you got what it takes. http://cgi.ebay.com/ebaymotors/Manua...item2561c1a01d
Old Mar 3, 2011 | 04:05 PM
ldgriffin's Avatar
ok cool maybe i"ll try that. Where abouts on the right side of the bike is it located? can u direct me to a guide with some pics somewhere.. i been lookin but cant seem to find anything.
Old Mar 3, 2011 | 05:04 PM
heres the guide for a replacement with a manual one, if you replace with a OEM one just ignore the manual adjustment parts i guess.
https://cbrforum.com/forum/stickies-91/replace-your-oem-cct-ape-107855/
Old Mar 3, 2011 | 07:07 PM
Dissevered's Avatar
dont... The CCT doesn't go bad, so replacing it won't help. You would have to replace your oil pump to get the OEM CCT to sound right. Get the APE manual tensioner.
Old Mar 3, 2011 | 10:48 PM
damuho's Avatar
Does it sound like this?:
http://www.youtube.com/watch?v=Spq5zcc0UZc
It's a video of the cam chain noise from my F2. The noise is only there when the bike has warmed up. No cam chain noise when the engine is cold.
This video is of the same bike after I installed a manual cam chain tensioner:
http://www.youtube.com/watch?v=sQCxwbEXrUA
What oil are you using in your engine?
Old Mar 4, 2011 | 07:03 AM
Just my personal experience but my OEM CCT was bad and i replaced it with a new OEM CCT and it fixed everything, so sometimes it does go bad.
Last edited by Joe 96 CBR F3; Mar 4, 2011 at 07:24 AM. Reason: Spelling like a fool
Old Mar 4, 2011 | 08:48 AM
ldgriffin's Avatar
mine only makes the noise when cold. as soon as the engine warms up it goes away. u said yours only doesit when warm????
Old Mar 4, 2011 | 09:00 AM
When my CCT went bad it only made then rattling noise when cold. Now it might have made it when warm but it must have been much quiter. the only time I heard it was when it was cold.
