NO MORE CLUNKITY CLUNK!
Old Sep 24, 2007 | 08:36 PM
FNQuickF2's Avatar
Default NO MORE CLUNKITY CLUNK!
Just installed the APE manual CCT today...Took about ten minutes...Baby purrrrs every start now...
RB
Old Sep 24, 2007 | 09:36 PM
notny41's Avatar
Default RE: NO MORE CLUNKITY CLUNK!
Right on! Yes, mine is minus the loud noise that sounded like the damn engine was destroying itself from within too.Hydraulic cam chain tensioner - gotta be the crappiest designed item Honda ever produced.
I modified an old FZR CCT and stuck it on mine. Works great!
Old Sep 24, 2007 | 11:24 PM
JWade's Avatar
Is that what that annoying sound that makes the my bike sound like it is about to explode when I start it sometimes? The CCT? Makes that Clunkity clunk noise for about 1-3 minutes until I get the bike warmed up?? But even after I have been riding it for about 1-15 minutes and shut it off for about 5-10 minutes, when I start it up again it makes that clunkity clunk noise.
Old Sep 24, 2007 | 11:34 PM
FNQuickF2's Avatar
ORIGINAL: JWade
That's exactly what it is...the cam chain tensioner.See, the stock Honda CCT is oil pressure activated and over time wears out and starts to loose its ability to keep adequate tension on the chain...resulting in the valves being out of correct timing. So when your oil biulds up enough pressure to put tension on the chain, then the noise goes away...
RB
Old Sep 25, 2007 | 12:20 AM
ohmartm's Avatar
Thats the same nosie mine makes, (when I can get it to run that is) but ya where did you buy yours from? Thanks!
Old Sep 25, 2007 | 12:28 AM
notny41's Avatar
I think they are about $55 from ape aren't they FnHotAvitar?
Old Sep 25, 2007 | 01:34 AM
jahnaboi's Avatar
See... my noise is even when my bike is warmed up meaning its my clutch. Because when I pull the lever in, its quite... and when I let it be, its clunking. Guess I gotta get a kevlar clutch kit...
Old Sep 25, 2007 | 02:02 AM
Sand.Man's Avatar
Jahnaboi, all of our clutches do that, just the plates rattling around... I dont think it means anything is wrong, it doesn't happen all of the time for me though fortunately!
Old Sep 25, 2007 | 03:58 PM
dawoonj's Avatar
OK....OK .... you guys are making want to put my CCT on!! I've only had it for a month already!
Did you re-use the rubber gasket?
Old Sep 25, 2007 | 07:56 PM
FNQuickF2's Avatar
These are 49 bones at streetandcomp.com.The gasket was a soft metal one that was already on there...
RB
